1955 Converting to 12 volt | Page 2 | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Thunderguy
Phil, you get around as much as I do. What size battery are you using in the 57 tray?
I have a 1957 battery tray in my '55 Tbird. I purchased it from NPD. The '57 tray will accommodate both the Group 29 and Group 32 batteries. The hold down is different depending upon which battery you use. I have a Group 29NF battery in my car. I bought mine from the local O'Reilly's store. They had to order it.
One more thing about the 12 volt conversion. 12 volts makes the horns really loud. This is a good thing as the brakes on these cars aren't the best. 🙂
The standard GRP 29 replacement battery is still currently available from for 1956 & 1957 models from the following sources.
1- Batteries + Bulbs www.batteriesplus.com/battery/car-and-truck/ford/thunderbird or call (800) 677-8278.
2- NAPA, Exact Replacement. P/N 390CCA 29NF BCL
3- Interstate Battery, P/N 29NF VHD
4- O’Reilly Auto Parts, P/N SSB 29NF
So far my car is still 6V I have had NO starting issue with it. It does have an Optima battery in it which in my experience will outperform the current lead-acid 6 volt batteries available. By the time I modify the Radio, Heater fan, 2 door window motors, buy a 12V gen or alternator, change all the bulbs and then have to buy a battery it just is not worth it to "fix" something that is not broke!
If you can get it to work 'as is' I'd say don't convert. Tons of time and money to fix something that ain't broke.
My friend and I are both purists and our 1955 Thunderbirds are still 6 volt. He has the 6 volt Optima battery like yours and he bought this clocking device so the Optima battery looks period correct.
I was considering converting my 55 T-Bird from a 6 volt system to a 12 volt system.
It was suggested that the conversion would be quite costly and quite complicated
right down to changing every light bulb in the car.
Thoughts??
I did the conversion on mine and followed an article. The seat and widow motors work fine ,just a little faster than 6 volt.
Changed from Positive ground to Negative ground.
I put a resistor on the clock to lower voltage . You can do the same for the radio.
Heater motor and gauges are all good on 12 volt although some kits come with resistors for those also.
Starting is much better due to increased cranking power.
I bought an alternator that looks exactly like to old generator just to keep the vintage look.
Vintage Auto Garage has some good kits for The 55s
Only takes a few minutes to pull the seat out ( have some help lifting it out) and that will make it much easier to change all the dash light bulbs.
I kept all the 6 volt stuff.
Thoughts??
This information is to honor its author, the late Walt Nuckles.
How to 6V TO 12V Conversion​
Some of you guys are making way too big a deal of the 6V to 12 V conversion on the 55 T Bird. For instance, you don’t, or should not need a wiring diagram. You don’t need to rewire the car. All the wire for the 6V system is twice as large as need be for 12V service. The only things you need to change under the dash are the dash lamp bulbs and maybe the cigar lighter if you still smoke.
The polarity for the clock must be changed to neg. ground from pos. ground. You may need to remove the clock to do this. There is a little tab that is designed to be positioned for pos. or neg. ground. Position it for neg. ground or just disconnect it if you like. Major damage will occur if it is powered up in reverse polarity. Install a 125 ohm 10 watt resistor in series with the 6-volt clock to drop the voltage to 6 or 7 V.
Of course the radio will need to be replaced or. converted to 12V, or powered through a voltage dropping resistor. It is not polarity sensitive. Your choice, or do nothing and disconnect it.
You do not need to change any switches or gauges. The fuel and temp gauges will work on 6 or 12 V and are not polarity sensitive. If you miss some of the lamps you can change them after they burn out, no big deal. The direction lamp flasher also must be changed for best performance but you can change it later.
The fuses may need to be changed to values smaller than original or use the ones rated for the 56 and 57 Birds. The tail lamps, the back-up lamps and license plate lamp will need to be replaced with the 12V ones.
Now for the firewall forward, you do not need to change the battery cables, the horns, the horn relay or the starter. If converting to a generator install a 12V one and a 12V 30 amp voltage regulator and wire it up exactly as the 6v ones or do the alternator conversion. This is done same as a 12V generator to alternator conversion. You will need to install 12V headlamps and park and direction lamps. No changes in lamp wiring or the light switch is necessary, leave it alone or repair it as necessary.
Of course you will need a 12V battery, there are 12v batteries that will fit the 55-battery carrier with little or no modifications, connect it neg. ground. The 6V coil can be used but the polarity must be changed, just switch the bat. And dist. wires or install a 12 volt coil same as used on 56 – 73 Fords or get good used ones from salvage yards from 60 – 64 Falcons. They have yellow tops.
Now for that very minor wiring change that has everyone confused. Install a 12V starter solenoid such as used on 56 through 73 Ford products. They are still cheap at Autozone. It will have the extra I terminal, I as in ignition. Run a wire from the I terminal of the 12V starter solenoid to the battery terminal of the coil, remove the ignition wire that is presently attached to the coil and add a new wire about a foot long to the bat. terminal before securing the nut. Now connect both the new wire attached to the bat. terminal of the coil and the original ignition wire from the ignition switch to a new ignition resistor, Mororcraft # DY 35. When the job is done, before you start the engine, remove the field wire from the voltage regulator and strike it (draw an arc) to the battery terminal of the voltage regulator in order to properly polarize the generator then reconnect the field wire to it’s position on the voltage regulator.
The heater blower motor, the seat motors and window motors will work on 12V, but they will run very fast. The seat motor running too fast should be no problem. The heater motor running on low speed will be acceptable. The window motors will require some expertise in use in order to prevent mechanical damage but most of my customers don’t change them. Can if you want, they may cost you up to $300 ea for 12V window motors. You might use a dropping resistor in the motor ground wire circuit to drop the voltage but I have not determined what the correct value would have to be. Maybe someone else knows. It will have to be a very high power resistor, maybe 1000 watts and it will give off some heat. I don’t have a 6V window motor to test or I would give you the numbers. I would recommend just using the window motors as they are and release the window switch before the window gets to its stop. This may take some practice but it is easy.
Walt Nuckles
4/10/01
Footnote
If the 6 volt gauges do not work when the 12 volt conversion is made install a 10 ohm 10 watt wire wound resistor between the gauges and the power supply to gauges. If the gauges still do not work it may be necessary to replace the gauges and the sending units with 1956 12 volt units.
