- 130
- 1955
😉 Wide Open Throttle. OR as my wife would say "WHY??? open throttle"? She doesn't get it!🙄😛OK, stupid question number 7,312 ...... What does WOT stand for? Vern :>)
Note: This feature may not be available in some browsers.
We're glad you found us via a search engine! Right now, you can join our club absolutely free and unlock member only features like the site search! This notice only appears once! It only takes 30 seconds to register, and we would love to have you as part of the World's largest Thunderbird Forum/Club! Click here to continue
Not at all, Wide open throttle, my bad sorry.OK, stupid question number 7,312 ...... What does WOT stand for? Vern :>)
You will most likely have to get a rebuild kit, replace the PV and the PV rod and diaphragm assy. The PV not in your old kits will tell you something, I would try the PV diaphragm assy first if you have one in your kits. I didn't have the best of luck with rebuild carbs hence I did them myself. Many folks bought adapter plates and put on new holley 600 carbs and that solved a lot of problems as the cars aged.I agree, but
when I tried to find a PV to replace it I couldn't find the part and it wasn't in any of the older rebuild kits I have! I assumed (not good) that they replaced the PV when it was rebuilt???
I have 3 kits and no PV in any of them. I want to keep the car all original, so no 600.You will most likely have to get a rebuild kit, replace the PV and the PV rod and diaphragm assy. The PV not in your old kits will tell you something, I would try the PV diaphragm assy first if you have one in your kits. I didn't have the best of luck with rebuild carbs hence I did them myself. Many folks bought adapter plates and put on new holley 600 carbs and that solved a lot of problems as the cars aged.
No PV available and they are not included in the carb kits!I have 3 kits and no PV in any of them. I want to keep the car all original, so no 600.
9503A is what opens the secondaries not the PV here is a picture attached and a link for parts IDIs this the PV?
9503A Diaphragm, carburetor secondary, 1955-56 (not included in 9A586 kits)
Yeah, I called. No PV available and not supplied in the rebuild kits.9503A is what opens the secondaries not the PV here is a picture attached and a link for parts ID
2140, 4000 Teapot Holley 4 Barrel Carburetor Parts
www.carburetor-parts.com
See what number it is and and order one on lineYeah, I called. No PV available and not supplied in the rebuild kits.
PV's are not available. I have a call into Mike's Carburetor's.See what number it is and and order one on line
Like you said it was warm, and the car is ok at driving speeds, the boog happens at start to WOT. just out of curiosity was the car ok before the rebuild carb was done? You can check the PV and see if it moves up and down if it's stuck down thats the problem if it's free check the actuator assy with a vacuum hand pump when it's apart. If the choke plates are open when it's warmed up and there is no problem then reset the choke and make sure it's working as the engine heats up from cold.OK, checked:
Idle (warm) 550rpm (480rpm in drive)
Timing 9° BTDC (1/2 between 8°&10°)
Max advance 34°
Max vacuum at idle 18psi
in gear 16psi
Choke plate ok/working
Answer from Mike's:
Subject: Mike's Carburetor Parts: Update Tracking #48422 Power valves for these aren't available new that I know of, you'd have to track down a used one somewhere. Pay attention to whether the issue occurs only when it's hot or cold, it could be a choke issue. Thanks Sincerely, Mike's Carburetor Parts
Don’t know if that particular problem existed b4 the carb rebuild, the prior owner had it rebuilt.Like you said it was warm, and the car is ok at driving speeds, the boog happens at start to WOT. just out of curiosity was the car ok before the rebuild carb was done? You can check the PV and see if it moves up and down if it's stuck down thats the problem if it's free check the actuator assy with a vacuum hand pump when it's apart. If the choke plates are open when it's warmed up and there is no problem then reset the choke and make sure it's working as the engine heats up from cold.
Don't feel bad, took me a while - Wide Open ThrottleOK, stupid question number 7,312 ...... What does WOT stand for? Vern :>)
By any chance are you using a 57+ distributor with the Teapot carburetor?I noticed this stumble/stall before I installed an electric fuel pump which I thought fixed the problem. From a start @ WOT she’ll accelerate and suddenly stall. If I back off the throttle she’ll start to come back to life, bucking for a few seconds then all is fine. Not electrical. Sounds like fuel starving or could it be the float level is too high causing spillage on hard acceleration off the line? It was warm today 85°, but she was running at about 75%-80% on the gauge. I did smell fuel prior and maybe thought vapor lock, but I have vented the gas cap, no vacuum from tank. There are no fuel leaks around the Holley 4000 Tee-Pot (like the secondary fuel tubes). Fuel filter is new & clean. Gas tank is new and all fuel lines are clean & excellent condition. This hasn’t happened in a long time since I installed the electric fuel pump. Is it fuel starvation or fuel spillage? WOT while driving is ok and she runs strong and smooth. No stumble on hard turns or braking.
Thanks
