C
calbears
- 4
- 1957
No good news all around. I bought a new instrument voltage regulator. Same result, the gauge moved slightly from pegged out to the left of empty to empty. I then ran a new wire directly from the gas gauge to the sending unit. Same as above, a slight move from pegged to empty. I then took the sending unit out of the tank and manually moved the float arm to full. The gas gauge then goes to about 5/8 full (not going all the way to full is another issue but not the primary concern). All of the above is the same as before I started replacing any parts (except for the gas gauge going to 5/8, it originally went to 3/4 when I manually moved the float arm to full but that was with another sending unit).
Regarding the voltage regulator, the one available only has one screw hole to hold it down, while the original has two screw holes. The one hole version is much easier to install because you cannot even see the second screw to remove the original, let alone trying to get the second screw back in.
