Nico57
- 5
- 1957
while all those can affect coolant temp, in older engines and older radiators the corrosions, rust, and block of the coolant passages starts the list of cooling probems, tho easy enough to be sure the engine is properly timed and that the advance both mechanical and vacuum are working.My observations over the the past 25 years are that overheating is most often a problem not actually related to the cooling system. Instead I find incorrect timing, an engine with quite a few mils on may be better timed by vacuum. Another common problem is still timing related in that an inoperative vacuum advance is common. Thirdly faulty choke mechanism is also quite a common problem. Last; how good is the overall engine condition. Although not necessarily related, all 292s and 312s have solid lifters. they should be adjusted at least every 10,000 miles. I prefer to do it annually with a P&G valve gapper. Too tight result: burned valves. Too loose noisy and lower performance. Before going right to the radiator a the source of the problems check the rest of the engines systems. One caveat is the it is not a big problem or expense to have the core rodded out. that can only help.
Nick
