S
- 4
- 1957
Note: This feature may not be available in some browsers.
We're glad you found us via a search engine! Right now, you can join our club absolutely free and unlock member only features like the site search! This notice only appears once! It only takes 30 seconds to register, and we would love to have you as part of the World's largest Thunderbird Forum/Club! Click here to continue
Starting fluid is not bad for engines. I would expect they would be bad on two stroke engines that rely heavily on two stroke oil and gas mixture or Diesel engines because of early detonation. On our engines there would not be a cause for alarm, especially used as intended. Again, a quick squirt to see if the engine continues to run is all you need.Never even thought about the lack of lubrication, good advice. :-J
Well gang, first I want to thank everyone for the help and suggestions. I got the new resistor and installed it only to have the same problem. Totally disgusted, I gutted the distributor of points and condenser and installed the electronic conversion. Once installed, the car fired right over on the first try. The only thing I can think of is that replacement condenser I installed earlier was also defective causing the car to react exactly as it did before the replacement. At any rate, it runs fine now and thanks again for the advice! Take care, Mike in Elma, NYSo does WD 40
Agreed, I don't even need the choke to kick in, it just cranks right up now.Glad you got it figured out. I went to the electronic ignition and the engine never fired up as well as it does now.
I used Pertronix, easy installation and the problem is solved.Which electronic ignition conversion did you use?
Thanks Mike. I have a 292 sitting in the garage waiting to power a new project, when I find one that is, and was wondering if anyone was happy using something different from PerTronix. Did you replace the coil as well? I kept the original coil on my '57 Tbird w/o a problem.I used Pertronix, easy installation and the problem is solved.
Okay, now you just flew over my head, how in morons terms (I'm feeling like one at the moment) do I conduct this test?So your using the original coil and resistor with a pertronix, may I suggest that you calculate your resistance with your current setup. It will work for a little while with the wrong resistance, but you don't want to burn out your coil or pertronix on a trip or in the middle of an intersection. It's an easy test and you will rest easy.
Wow Bobioknight, just when I thought I was home free you gave me some more homework. I need to read through the paperwork that came with the unit and brush up on my skills. I'll get to it Monday or Tuesday and let you know how (if) I made out okay. Thank you for the info, I hope I can get this done, I intend to drive this Bird from Buffalo to Dollywood Tennessee and back in September.Your pertronix should have the specs on a sheet for the amount of resistance it needs. I have the first version and it requires 8volts so I needed to read a total of 1.5 ohms at 12 volt. ( 12 / 1.5 = 8 )... Ok so take your volt meter set to ohms, disconnect the wires from your coil take a reading. Take that reading and divide it by 12 the total should equal the ohms needed by the pertronix. If your too high, then you need to add a resistor into the connection on the positive side of the coil then recheck your restance of the coil with the resistor, take that total and divide it by 12 and verify that matches what the pertronix needs.
There are many options for coils and you can match the resistance needed with a single coil or a coil resistor Combo. But don't run it too hot or too cold, your primary voltage should be within spec of the pertronix.
Don't worry about checking the secondary resistance by checking the coil wire that goes to your distributor, only the primary resistance matters testing the pos and negative posts on the coil.
Once you verify the correct resistance, you can open up the spark plug gap for bette performance if you would like.
