M
My61bird
- 0
- 1961
Thanks we're just a little south of Raleigh NC
Note: This feature may not be available in some browsers.
We're glad you found us via a search engine! Right now, you can join our club absolutely free and unlock member only features like the site search! This notice only appears once! It only takes 30 seconds to register, and we would love to have you as part of the World's largest Thunderbird Forum/Club! Click here to continue
My61bird, it the oil pressure is still poor after you put in a new oil pressure sensor or mechanical oil gauge, Yes dropping & cleaning the oil pan would be a very good thing to do.If you don't have reliable oil pressure your next move should be to drop the pan. . . . . . .
I think he said the oil pressure was good at start-up but the light came on later. Gunk got spread around and plugged up everything. pulling the valve covers may reveal a lot.The oil pressure may be the reason it was parked!
Did it look something like this?I pulled the pan off the old engine in a '55 and there was so much sludge in the bottom I'm surprised it got any oil at all. Next was a '57, the cover & screen around the bottom of the pickup tube had come loose & dropped to the bottom, blocking the pickup, no usable oil pressure under 1200 rpm!
The crank had to be turned... a lot. 😳
I've seen hydraulic lifters go bad. Plugged and won't pump up. My 'Y' block has solid lifters so that is another good possibility I didn't think of. But the compression difference is still an issue.Lifters are hydraulic, but maybe a lifter is ticking.
Give it a run!
