All right here we go this is the post to complete the French toast! It has been 2 months plus of money, time, brain power, blood, and patience to get to this. And by the way don't get me wrong I've read hundreds of threads with the same issue and not the same cause so this MY STORY. I met this beautiful car probably 4 years ago. Friend of a friend had it in his mother's garage It fired right up sounded good. I told him don't ever sell it without calling me. You know time goes by and forget the car anyway... See the guy asking about the car he said he just posted it on the marketplace I said hell if you did cuz I'm about. When I get to the car feels beautiful as it was but it won't start Long story short New distributor and points not set correctly I think I got it under control so I buy it. It took a week before I rented a tow dolly and pull it home because it wouldn't stay running for more than 6 minutes or so. From cold start sounding beautiful half a bump at the starter she's on... Get the operation temp and no worky! Sometimes she would start right back up and die shortly after other times she wouldn't start for an hour maybe six. Buy a new distributor put it in and issue continues so I start vapor lock problem solving. I reroute my fuel lines away from the engine away from heat no results. And that was after I did a dynamic cleaning and rebuild of the
Edelbrock carburetor that was on it. I then check the
sending unit in the
fuel tank because of some other threads I read and yes I had a horrible
sending unit. And a pinched vent line and a pinched feed line. Uncrimp the feed line by new
sending unit vented fuel cap and while it was down I electrolysis the
gas tank and did a red coat lining. No change same problem I test this and I test that... Find a picture which is one of my last posts of a
carburetor I swapped the vacuum lines tune the
carburetor and she ran so beautifully that I felt like a high school kid doing numerous different things lol. The next day I get home she will not start at all couple hours of backtracking backtracking and the distributor the speed master procomp 6000 is not producing fire Don't forget it's brand new..! So to make it quick warranty claim on a brand new
part new distributor drops in so beautifully the car runs completely different and my problem is solved.!?!? So so long story short Brand new
part on something I knew that was wrong was faulty from the get-go cost me about $600 in just
parts of mixed diagnosing and we don't want to talk about time. So the whole time once the car got the temperature a component of the distributor would fail therefore the car dies It would intermittently work or it wouldn't work at all until I discovered the real problem of complete failure. More of the story don't trust it just because it's brand new especially on old stuff! You have fuel, you have spark, at the correct time. And your old motor will run sorry for the long-winded finish to a thread but it needs to be explained and I guess we'll see each other somewhere in the future cuz now we're going into vacuum brake switches and window back windows electric windows! Also just to be said after a can of neverdull A six pack of beer and a Vicodin I hate chrome!!!
