Shadrack
- 98
- 1964
I think I see a black-red wire on that connector plug. The only black-red wire is for the back up lights. My guess is the other wires on that plug are white and two red-blue wires. The black-red and white are for the back up light circuit and the red-blue wire is from the ignition switch to the solenoid and passing through the safety start switch. That plug goes to the back up light and neutral safety start switch. (probably on the steering column above where your feet would be when driving the car) Also, the black-red comes from the fuse box to the plug and there should be another black-red paired up with white. The white goes out to feed the windshield washer switch. I would guess that they bypassed that back up / neutral start switch when they put in the start button instead of actually repairing whatever it was that was stopping the car from starting. Do you have working back up lights? Will the car start in any gear other than park or neutral? (it shouldn't) Do your windshield washers work?
I will go take another picture soon - the hospice nurse is here now working with my mom and giving me a bit of break. I really hate that they hacked up the car that way! I will check to see if it starts in other gears as well - but I am pretty sure it does not. I also do not think that I have backup lights. I do not have the bag filled for the fluid and have not tried the motor though. With all they bypass could that cause the dead interior lights or is that a fuse? The gauges light up a speedo with the headlight switch - but otherwise, no lights inside.
Do you think the car ought to take a trip to the auto electrical shop? I don't want a fire hazard! I will take any suggestions. THANKS IN ADVANCE! I REALLY appreciate the help.
