old timer
- 4
- 1966
After reading everthng I have had and still have a little. If you want to clean your cooling system get Permatex Heavy Duty Radiator cleaner. Over the 65 years I have used everything from Coke A cola up. This the best, you order it at O'riellys or on line. The other thing to keep in mind is when filing your cooling system set temp lever to high, turn on heater fan blower high. add coolant slow , watch temp to let thermostat to start opening then go fill slow. When feel heat coming from your heater finish filling. This keeps air locks from hapening. I had a garage change coolant and did not do that I had problems. If you live in a climate where it is warm like me you do not need a thermostate.
