2002 draining battery at night | Page 2 | Ford Thunderbird club group 1955-2005 T-Bird models
I've been chasing a parasitic power drain of about .33 amp for a couple of weeks (part time). So I have now systematically removed ALL fuses except for fuses 23,24,27,32 (SSP fuses) and 25 (P-JB) fuse in the rpdb. Removing any of these make the draw increase (under 1a) and when replaced it goes back to .33 in less than a minute.
Diagnosed with OBD (Forscan) and got the following codes:
1. P1000 = PCM (even after driving it around for an hour) OBD systems readiness test not complete. Possible Powertrain Control Module failure. (covered by fuse 18 in the fpdb - pulled, no impact to amp draw.
2. B1830 = GEM (Lock switch unlock switch circuit) - door unlock disarm switch circuit failure 419-01a pinpoint test b shows the issue - the switch is dead, the anti-theft won't disarm with driver side key unlock. Unfortunately this part seems almost impossible to get, so I'll probably have to remove the panel and disconnect it to see any impact. covered by fuse 2.30 (passenger compartment) - pulled, no impact to amp draw.
3. B1242 = EATC (Air flow recirc door driver circuit failure) - seems to work when I test it manually with
continuous DTC - switch works, servo % changes, etc. but the inside temperature on continuous DTC shows 20 degrees higher than the outside even with the top down. So it looks like a bad temperature sensor. Can't find a fuse to cover the EATC but DATC covered by 2.30, 2.29 no impact to amp draw when pulled
4. Happenstance - I found the side mirror adjustment switch doesn't work for either side, have to replace. covered by fuse 2.34, no impact to amp draw
I'm almost resigned to getting a replacement REM, but it would be nice if there was a way to diagnose the amp draw with no fuses except rpdb 23,24,25,27 and 32. It's a pretty spendy what-if though.
Any other suggestions when a normal parasitic draw fuse test fails to show anything?
Don't know if this has already been discussed...my battery on my 2002 retrobird is draining while in the garage...no lights remain on except the red blinking diode on the dash...doors trunk and hood are all closed...it doesn't make any sounds. Is there a switch somewhere that has notoriously been draining batteries or is this something new.
We had the same issue, it was the Radio Amp in the trunk, removed and it stopped right away, found a used one on Ebay, loud and clear now
DTC code GEM B1830 pointed to the perimeter alarm system door unlock switch - I took off the panel, unplugged the switch and my draw went from .33 to .03. Unfortunately the switch is a component of the driver's side door wiring harness, so it may be difficult to replace.
But detective work done!
This is kind of a no-brainer, but I had a new battery bleed down also. I didn't realize the lighter and accessory sockets stay hot when the car is off. With my other cars they turn off immediately or after a delay. I had a USB charger plugged into the accessory outlet, but I didn't have a cord or phone connected so I just forgot about it. Evidently the charger stayed on (and may have even had a small LED burning). With that unplugged I've had no more problems.
Again, I recognize other are having more complicated issues. Just wanted to share this observation.
My battery in my bird drains to zero about every 4 days if cables are hooked up. I installed battery disconnect to potentially slow it down until I could find the problem. I cannot find anything except interior lights in rear view mirror that stay on intermittently. Don’t know if that’s the culprit but help is needed. Anyone have similar issues let me know what to do.
Thanks
Black02
Thanks
Black02
The six disk CD player is most likely the problem, find the fuse near the glove box and pull it out. If it solves the problem, update the radio ?
I don't drive my tbird very often; it sits, sometimes for a month or two. This has been fine for years, but recently the battery went dead. I couldn't get the battery to take a charge when it is connected to the car, even at high charge rates. Any idea why that would be? It charges fine when disconnected. I figured that maybe there was something drawing down the battery when the car is off, but I measure 0.05 amps of current, which should make the battery go dead in 1.5 months, give or take. Any idea what is drawing this tiny current? The current dropped by half when I pulled one of the mondo relay fuses in the trunk (#2), so there is more than one current draw going on.
Pull your radio fuse and see if the battery holds. That was my problem on my 02.
Could be something else, even battery itself, but when i first got my 05 it would not last 2 days of sitting.
Turned out to be the defective REM - rear electronic module was causing intermittent but often huge draws that were taking battery down
It is located below collapsed convertible top
It was then replaced and been fine since .. although battery, brand new just before the problem, lasted only 3 years - Mechanic figured battery life was hurt by the previous excessive draw problem
Is there a specific diagnostic test for REM?
There are diagnostic codes for certain failure modes, but from my experiences with my 2002, the kinds of failures as described in this thread are caused by transistors in the electronics modules (both rear and front). Most cars I've worked on use the electronics module/computer to switch a relay on and off, where the relay handles the higher power. For some reason Ford decided to switch many of the power circuits directly with transistors in the electronics modules. The problem is that transistors wear out over time, and start to leak more and more voltage. Depending on how many leak and to what degree, you'll start to get battery drain problems. In my experience, relays will fail in a more catastrophic manner, which is a good thing because the problem is easy to detect, and the relay modules are in sockets so they can be easily replaced.
I had my FEM rebuilt which replaced all the transistors, and that fixed illumination problems I was having. I need to have my REM rebuilt, too. The REM handles a handful of lighting switches, and I see various amounts of voltage sent to the lamps, even though the car is off.
I’ve never put an ammeter across battery terminals but an ammeter goes in series with a load to show current flow in amperes or fraction thereof
Hi, Don't leave key inserted into the ignition switch. If key is in switch the steering column circuit is energized. This will drain the battery overnight.
When you leave the key in the ignition, even with the key in the off position, the key warning switch sensor in the ignition switch is still active. When active, the microprocesser instrument cluster will not allow the instrument cluster to go into sleep mode. That's why when you remove the key from the ignition switch the steering column will tilt all the way up and in.
Always make sure that the ignition key is removed from the ignition switch when checking for current draw. When the key is inserted into the switch, the system is armed and controlling the steering column, pedals and mirrors and other circuits. This will cause the battery to go dead overnight.
Something is draining our battery, had the alternator checked and it tested as good. I wonder if it’s the alarm system but not sure where to start. Local shop could not find anything. Anyone had similar?
