I
intensifi
- 10
- 2004
The diagrams look fine.
Note you will need a trim tool to pry the connector for the rear window defroster wire off the bulkhead. Once you do that, you can disconnect the rear window defroster at the connector junction (NOT THE WINDOW ITSELF) And then remove/pull back the fabric covering the REM and other modules in the area.
For the splice itself, you can make a military splice or use a positap device.
suggest a folded up towel to protect your shins from the seat rails.
