Hold on to your hat....here's a whopper of an update:
The windows work. Everything, both sides, both switches, up, down, auto down, everything.
What happened? My mother returned from Florida and she wanted to take it out for a spin and get it washed, so she wanted me to "put it all back together". I just had the kick panels off and the driver's knee panel and the
soft top halfway up. I already had the door panels back on and switches all back together. Because I was accessing the REM under the top, I had the
hardtop off and the
softtop up partially to allow me to pull back the water shield and check all the wiring into and out of the REM. Well, I put the
soft top back down all the way, readying the install of the
hardtop and figured I give the windows a try since one of my hypotheses was that there was a poor connection somewhere between the REM and the driver's master window switch.
Well, with the top down, that poor connection was most likely made good again(on the YEL/RED wire) between the REM and the driver master window switch, and now everything works again. Its most likely a split in the wire somewhere or a poor connection from the wire to the crimped connector that goes into the REM(I'm dealing with a similar situation on my Crown Victoria's Lighting Module right now, too).
At the end of the day, I don't care anymore. It works, making it easy to pay at the car wash and to get food at the drive through again. She doesn't take the
hardtop off in the summer here in Central California because the summers regularly get over 100º for a long three month stretch and it's way more enjoyable with the
hardtop on and the
A/C blaring.
Until such time that the windows stop working again, and I need to trace down that YEL/RED wire coming out of the REM, my hands are off the car(also because everything else works perfectly).
