B
BrianM
- 5
- 2004
Are the Jag heads wider than the Ford? The Ford 3.9 is already a tight fit. The WIKI on the AJ engines says this about the 3.9:Will the 4.2 engine have sufficient free space to rock the maximum amount on its rubber engine mounts during engine torque swings?
"The 3.9 L (3,934 cc) AJ30/AJ35 variant is a unique displacement used only by Ford and Lincoln and is built in Ford's Lima, OH engine plant. Bore and stroke is 86 mm × 85 mm (3.39 in × 3.35 in). The AJ35 version introduced for the 2003 model year added variable valve timing of the intake camshafts and electronic throttle control. While the block, crankshaft, pistons, and connecting rods are all unique to this displacement, many other parts are shared with the AJ-V8 engines produced in the UK by Jaguar." Heads are not mentioned as being unique to the LS and Thunderbird applications. Just wondering.
