ranariz
- 14
- 2004
Gen11 'Birds offer a pleasant driving experience while still looking great with the Retro styling. Some complain about Gen 11styling however we always get looks from people when out and about in Da Bird.
We've had our "bird (AKA "Da Bird") for 11 years now with 37K miles on the clock, purchased in NC with 14K miles. During that time, Da Bird followed us from NC to OH and then back home to Tucson, AZ. Didn't see very many 'Birds in NC or OH but see quite a few back here in Tucson.
Some ruminations:
- Ford / Lincoln dealership for fluid changes always best choice. Inexpensive for minor repairs and maintenance unless you run into problems with major components such as power modules.
- My experiences with 'Bird issues include:
> Limp Mode shutting down power. I have a write-up in this forum relating to corrections. Net: Replaced TPS on Throttle Body Housing. Removed the awful Gen 1 TPS to the Gen 3 TPS which tells you something. Not easy to do but can be done if you have some mechanical aptitude. Don't be talked into replacing the throttle body housing by the dealer as the replacement might not have the latest Gen TPS installed. Plus it'll cost upwards to $1,500 or more to replace.
> While changing TPS, I changed spark plugs and installed complete set of new COPS (Coils on Plugs). A preventative task that adds to reliability.
> Recently had an issue with the Mass Air Flow sensor that I had to take to dealer for repair. Would have done this myself however I couldn't diagnose the issue as car needs to be running to use the OBD II tool.
= I suggest investing in an OBD II plug in device. Helps you diagnose issues that can be DIY tasks.
> Replacing the spare tire. Mine pretty much rotted away.
> Rubber bushings on rear suspension links have deteriorated however the ride is still fine. I'll replace the links once I notice changes in handling quality.
Hope this helps in your decision.
Regards,
Some ruminations:
Regards,
