Hi there, greetings from Scotland. I have recently took ownership of a 1957 Thunderbird with the 312, car was in Florida and was restored from the ground up 8 years ago, 2000 miles have been done since. I know this is a much debated topic but threads I have seen are a few years old now. Regarding engine oil what’s the recommendations with this, previous owner said he ran standard pennzoil 10w 30 with a ZDDP additive, the car doesn’t leak a dime from anywhere right now, it drives smooth and quiet. Temperatures in Scotland rarely get above the 70/75 mark in summer so nowhere near what he was driving it in Florida. Should I continue with the same product or is it worth changing?
Also for flushing out the
radiator/cooling system is any good prestone with a 50/50 blend with water do the trick? I’ve ordered the
shop manual so I am sure the details will be there but regarding transmission and
power steering servicing intervals how long should I give it before changing? I am going to bleed the brakes as previous owner said he hasn’t done since he got it from the restorer, DOT 3 I’ll use in that.
Any other recommendations or advice with this topic is much appreciate, thanks for your time.
Regards
Chris
