You will find this forum invaluable. First, you have to LOVE this car to own it. There's a lot of finicky nit-picky little annoying things that are well documented small problems - most of which you can fix yourself with some patience and by asking the right questions.
Parts seem readily available. Get yourself a
FIXD scanning device that works with your phone.
http://amzn.to/2DNR21F
It will pay for itself the first time you use it. You can also clear errors and
check engine lights with it if you think you've fixed the problem. If you don't already know - common problems are (some of which you've noted):
Coils (there is a separate
coil for every
spark plug - mounted on top of each
spark plug under that little cover on the heads)
They are not too difficult to replace and you can do all of them for around $150 - vs. $1000 from a dealer.
- Oxygen sensors - oh yea........there are 4. LOL
- Door sensors (there is a left and a right. Despite what some tell you they are NOT the same
part number.) If your car "thinks" the door is open, the windows will not operate correctly.....even when you calibrate them as described in the manual. Fix the problem, not the symptom.
- Old spare tires tend to explode or be flat when you need them.
- 91 or higher Octane ....................good luck. It pretty much doesn't exist anymore. Put 90 in.
-use 5w20 engine oil ONLY.
-use YELLOW coolant ONLY.
- NEVER allow your battery to die. If you do, your transmission will have to learn how to drive again. Use a
trickle charge (
battery tender) when not in use for extended periods of time.
But on those sunny days...........when the top is down.........your wife will wonder why you are smiling so big.
The car kicks @ss!
