G
greyfox11
UPDATE EMAIL ADDRESS
Inferno Red wrote:
"The "Model Master" paints by Testors(or any model paints for that matter) are not made to and will not hold up to outside weather conditions...certainly not on a metal surface WITHOUT a primer base coat!The first time it is hit by highpressure water or a few trips through road grime during wet weather,it will start to chip off!Please invest in some actual auto paint...may be more expensive BUT it is designed to take that punishment...model paint is designed to sit on a shelf and look good.Just trying to save you some frustration."
He is most likely 100% correct. If someone could get an auto paint store to mix up 1/2 pint of the correct color it would be enough to paint all of the center caps Ford will produce in the next 5 years.
Point well taken though.
