Boozeman
- 20
- 1957
Thank you for the thoughts and replies - much appreciated!
I didn't get the starter reinstalled last night - the family had other plans. Hopefully I'll have time to do that tonight. I'll be sure to check the ground from the battery to the block and the ground from the block to the firewall. I'll also bench test the solenoid (I agree that I've never seen one cause something like this, but I've also never seen something like this). When I installed the Pertronix, I bypassed the ballast resistor, but left a dummy wire attached to it and the coil just for looks. This was one of the first things I checked, and the resistor is indeed insulated from ground, so that's not the culprit. I don't think the coil is going bad, because it's only about two months old. I'm still running a generator, so it's not a faulty alternator. The battery connections are tight and clean... in fact, I have a quick disconnect on the positive side, which was how I was able to get it disconnected so quickly. Thank you again for all the ideas - I'll check out the grounds and the solenoid tonight and report back.
