L
LON O'CONNELL
UPDATE EMAIL ADDRESS
Gearhead,
The only reason the T-Bird has the x-bracing is because it is a convertible. Had the vehicle been built as a coupe there would be no need for the x-bracing. On a couple the roof is the main structure bracing the car.
If you think the bracing is bad, you should see what other manufacures have done with convertibles. In the 60's GM's convertible Corvair had a 3lbs coffee can filled with cement and a eye hook stuck into the cement. Four of these were hung, one each, in each corner of the car hidden from view with trim and inner fenders. This was to help the car from flexing in the middle. Nearly every convertible on the road has extra bracing of some sort or another.
1998 Taurus SE Sport 24V
