64ZCODE
- 303
- 1964
Hi Don
That's good news. Likely with the new battery, the starter's cranking power and speed will be up to snuff. And you might find that some of the nagging electrical issues you've been battling resolve themselves with adequate juice available from the battery.
Once the new battery is installed in the car, you can check to see if the alternator is OK by using the multimeter to measure voltage across the battery terminals. With engine off, voltage should be around 12.6 volts. With engine idling, voltage should measure 13.5 to 14.6 volts. Then do the stress test. With engine idling, turn on all the accessories (headlights, heater blower, radio). If voltage across the battery drops below 13 volts then the alternator may be bad. Check to make sure that all the connections in the charging circuit are good (battery terminals and other electrical connections are clean and tight).
Doug
Doug
