I bought a new fuel filter element. I will install it in a couple of weeks. One cannot rush this type of work.
The fuel filter for your Thunderbird is located inside a glass bowl which is in the fuel line directly above your fuel pump on the driver's side of the engine compartment at the front of the engine. To insure that your car's fuel system is working properly, it is important that you periodically change the fuel filter.
When changing your fuel filter you will be working with gasoline. Please use caution!
I purchased my fuel filter from one of the Thunderbird
parts suppliers; however it also can be purchased locally through
NAPA. Make sure the new fuel filter comes with the rubber gasket for the glass bowl. The rubber gasket slides over the filter element. The filter should have a bit of material protruding past the filter element so the rubber gasket presses against it and holds the filter element in place against the filter housing. Before replacing the fuel filter, make sure that your car is on level ground and the engine is not running. Now find the glass bowl. The glass bowl is held in place by a wire harness with a wing nut at its base. By loosening the wing nut at the base of the glass bowl, you can push the wire harness over to one side and remove the glass bowl from the fuel filter housing. Be careful to catch any gas that may spill. The following tip is not necessary, but I found that it made replacing the fuel filter much easier.
Using a 1/2" and 9/16" wrench, loosen the two brass gas line fittings which connect the fuel filter housing on both sides to the fuel lines. You will only need to loosen the fittings enough to allow you to swing the filter housing upside down so that the fuel filter element will be facing up, directly at you. Once you have rotated the filter housing, remove the fuel filter element. Next, install the new filter element with the paper side towards the fuel filter housing and install the new gasket over the filter element being careful not to fold or kink it. Make sure the gasket fits evenly in the recessed channel of the filter housing. Reinstall the glass bowl and place the wire harness back in its original position around the glass bowl. Tighten up the wing nut so that the glass bowl fits snugly into the fuel filter housing. Make sure your gasket did not shift out of the channel in the filter housing. Turn the filter housing, with the glass bowl attached, back into its original position so that the glass bowl is underneath the filter housing. Now retighten the brass gas line fittings on both sides, start the engine and check for leaks.
