Critterpainer
- 94
- 1955
Ward. Thats NOT the way a "gen" light works. Turning on the Ign with the engine off puts power to the bulb from the battery. The ground is supplied by the generator NOT making a charge and allowing the bulb to ground by backfeeding through the Gen. When the car is running the Gen is making voltage that matches within a couple of volts of the battery voltage. Bulb has power to both contacts and no ground. Out goes the light.The bulb should be grounded by the dash. The issue is up the harness and why it's grounding at the alternator with the key off.
