- 1,111
- 1955
As far as the fuel disappearing from the float bowl, the problem is not the carburetor it's the fuel pump. Normally, when you haven’t driven the car in four or five days, all of the gas has drained out or evaporated from the fuel pump. Classic Auto Supply sells a fuel line check valve that will eliminate this. The part number is 9160CV.
https://www.classictbird.com/Check-Valve-Fuel-Line-Fuel-Pump/productinfo/9160CV/
To make sure it’s not the carburetor, disconnect the fuel line at the carburetor inlet and then wait 3 to 4 days. Check the fuel level in the float bowl and I bet you it will be full.
If you are looking for information on how to wire the electric fuel pump, I would wire it to the “I” terminal of the ignition switch and then through another on/off switch. That way it will only be on while the engine is running and you can turn it off if you want to. You could also wire it through the oil pressure switch with a relay, that way if the engine dies in case of accident once oil pressure is lost the pump will shut off.
