Shadrack
- 98
- 1964
I would guess, based on information from 40birds, that connection there was an attempt at bypassing the brake switch relay. If you check continuity from those back to the green-red wire at the fuse box you may find it is the wire you are looking for. The other wire you have there probably goes to the brake light switch.
I have updated the sketch I drew and I hope this helps you a little bit.
First Steve....let me say....this is like PURE gold! Thank you so much for all this help!! I will check continuity on the wires ASAP.
I am trying to look at this and use it as a model:
https://www.macsautoparts.com/ford_...relay-harness-kit-1964.html?ndlvid=7b1-22eba8
It would seem I am missing a breaker - anyway to piggyback off another?
