Shadrack
- 98
- 1964
I would say the "smoke show" was most likely because when you hooked up the green-red wire at the lug it was also connected at the solenoid through that hack fuse. Hooking to two power sources on one wire at the same time is not a good thing.
And yes, I would like to see what the hacker did right there where the wires are spliced together. I'm inclined to say just to remove the hack and we'll fix it in a more correct method but don't do that just yet. Let's first figure out what you have going on there.
Hey Steve,
Okay I have created a crude drawing of my engine bay. I also have included a bunch of pictures. I took the wiring looms off today and found that a wire (green/white) was disconnected/cut/broken and paired with the green/red wire and it was hooked up to the boot/cap (this was the one that showed continuity with the green/red wire) the other side of the plug/cap was hooked to the 15 amp fuse. The other side of the 15 amp side fuse is tapped into a wire running (it is also spliced in a few spots) to the starter solenoid and runs into the firewall.
I know this all sounds nuts but I think my problem partially lies with the green/white wire is broken and not connected to the boot - I think it is supposed to be connected to the boot.
You will also see where the loom from the boot/plug & relay plugs into two brown wires that looks like even they are spliced into green and a green/red that goes into the firewall.
Ask as many questions as you need - I need some serious help and I appreciate it.
I can only upload 10 pictures at a time so I will reply to this with the rest:
